SpatialFilter vs Clipper
  • October 18, 2013
  • 248 views
In which type of situation would you use one over teh other? Here is my use case: I have a polgon and I want to find all the features that are inside or intersects that polygon. It seems I can use both transformers. Just want to here what the community has to say.
Thanks,
Sean
Best answer by fmelizard
I would use the spatial relator/ filter
fmelizard
Forum|alt.badge.img+22
  • October 18, 2013
  • October 18, 2013
Spatial Relator works good
Thanks,
Sean
fmelizard
  • October 19, 2013
Yes -- the SpatialFilter will do far less work than the clipper, so if you don' t need to know exactly what parts are in both, just need to know if they "relate", then yes, SpatialFilter is best.
