I am using the SpatialFilter transformer to split a large dataset into two shapefiles. I have tried every configuration within the SpatialFilter however it keeps rejecting some of the Candidate polygons. The strange thing is that if I add a BoundingBoxReplacer before the SpatialFilter it works fine, however it outputs the bounding box and I need the original feature output. I have tried using the 'Use Boudning Box: For Candidates Only' but get the same rejection.
SpatialFilter rejects candidates even though they intersect
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
