SpatialFilter - Geometries within an area
  • Jun 29, 2016 2:34 PM UTC
  • 5 replies
  • 97 views
I wanna test if geometries are within an given area, I found the Spatialfilter transformer, but it doesn't work as expected.
Geometries that i'd like to test were set as Candidate, the area as Filter and Tests to perform to Within. But it does not test for candidates within the filter, instead it tests if the filter is within the candidate, which is not what i want to achieve.
Do you have an idea what I am doing wrong, or what I can change to make it work?
I am using FME Desktop 2015
thx & br,
mel
Best answer by david_r
Have you tried using CONTAINS rathar than WITHIN?
  • Jun 29, 2016 2:37 PM UTC
  • Jun 30, 2016 7:46 AM UTC
Thanks, that seems to work.
I have this problem. I want to have geometry after using spatialfilter, but it gives me just text as a output.
23
23
@engshabanpour13​ make sure both Filter and Candidate features are in the same coordinate system. Lots more on spatial comparison here.
thank you so much.
