sourcedataset
  • Jan 17, 2018 8:51 PM UTC
  • 69 views
I'm trying to populate an output attribute field in a file geodatabase with the input sourcedataset_ACAD. Unfortunately, since I'm iterating through a folder my output ends up with pathname\\*.dwg instead of the actual dwg name. Obviously, this works fine when running one dwg at a time, but I have thousands to convert.
erik_jan
Forum|alt.badge.img+26
  • Jan 17, 2018 8:52 PM UTC
You can use the fme attribute fme_dataset or fme_basename. This contains the name of the source file.
Thank you so much from a total newbie to FME!
