Sorter vs Statistical Calculator
  • Nov 9, 2022 4:55 PM UTC
  • 105 views
I need to remove duplicates from varying sized datasets. Would it be more efficient to use a sorter with a sampler or a statistical calculator with a tester?
Best answer by dustin
I would use the Sampler with Group Processing set to whatever your duplicate value is. No need to use the Sorter before it. Alternatively, you can use the DuplicateFilter.
dustin
Forum|alt.badge.img+36
  • Nov 9, 2022 5:02 PM UTC
  • Nov 9, 2022 5:17 PM UTC
Didn't even think of that! That really helps keeps things simple!
  • Nov 10, 2022 11:19 AM UTC
I would avoid both the Sorter and the StatisticsCalculator, as they are both blocking and can consume a lot of memory for larger datasets.
As @dustin​ mentions, either the Sampler with a Group-By, or the DuplicateFilter (my personal recommendation) will work.
@bibold​ I would agree with @david_r​ - try the DuplicateFilter first. It should give better performance than sorting
