Snipper with multiline case
  • Jul 14, 2020 5:40 AM UTC
  • 61 views
xtian79
Using Snipper with a geometry that is composed by a IFMMEMulticurve, The Snipper returns 2x the values expected (as the multicurve includes 2 IFMELines).
Let's take a look to the example:
this is how it is seen on the Data Inspector:
IdValuea = 10b40c60
Something like this sketch is the result:
the points that their measure are beyond the minimum/maximum measure of the line, are located at the beginning/ending of each segment.
How could I manage this behavior?
Best answer by caracadrian
Use a Snapper set to End Point Snapping and a Snapping Distance value of what you consider an acceptable tolerance before the Snipper
caracadrian
Forum|alt.badge.img+23
  • Jul 14, 2020 9:56 AM UTC
