Snip polygons into smaller pieces
  • Mar 9, 2022 9:29 PM UTC
  • 5 replies
  • 166 views
katt
Forum|alt.badge.img+12
I have a polygon with a line inside. I want to create several polygons out of the big one by snipping the line every 1 Meter. See my image for reference: I want to cut the red line every meter and split the polygon at that point by using a perpendicular line to the red one. As a result I will get more than 10 polygons.
danilo_fme
Forum|alt.badge.img+58
  • Mar 9, 2022 10:38 PM UTC
Hi @katt​
Did you try to use the custom transformer PolygonCutter?
Thanks in Advance,
Danilo
katt
  • Mar 9, 2022 11:04 PM UTC
Hi @katt​
Thanks in Advance,
Danilo
Yes, but it didn't work properly. I managed to create the perpendicular lines. How can I combine them to polygons ?2
@katt​ if you feed in the perpendicular lines and the polygon into PolygonCutter, that should cut your polygon for you as @danilo_fme​  suggests. I've attached an example workspace (FME 2021.2). If this doesn't work with your data, perhaps attach a small example dataset.
danilo_fme
  • Mar 10, 2022 10:58 AM UTC
Thanks @Mark Stoakes​  for endorse my answer.
  • Mar 10, 2022 3:35 PM UTC
Hi @katt​ , the BoundsSplitter transformer from FME Hub could also be helpful.
