Smallworld to Json
  • Feb 21, 2018 8:44 PM UTC
  • 60 views
I created a workbench translating data from Smallworld to json. It was just a plain Smallworld reader and then a connector that connects to write to a json writer. After the translation is done, the FME Data Inspector tells me there is no geometry in my json file. Do I need some sort of transformer in between to create the geometry in json? Thanks!
zzupljanin
Forum|alt.badge.img+5
  • Feb 21, 2018 9:44 PM UTC
if you put Inspectors instead of JSON do you get geometries?
erik_jan
Forum|alt.badge.img+26
  • Feb 21, 2018 9:57 PM UTC
Sound like you need GeoJSON.
Or extract the geometry in an attribute using the GeometryExtractor or the CoordinateConcatenator transformers.
