SliverRemover finish without output
  • July 29, 2013
  • 6 replies
  • 65 views
I ran SliverRemover on polygon table expecting an output but the translation finished without error and without output. First time I see this in FME.
What am I doing wrong?
Log:
2013-07-29 15:24:42| 454.5| 0.0|INFORM|Tagging...
2013-07-29 15:25:05| 477.1| 22.7|INFORM|Tagging done (23 s).
2013-07-29 15:25:05| 477.1| 0.0|INFORM|Repairing...
2013-07-29 15:25:05| 477.5| 0.3|INFORM|Repair successful (0 s). All polygons are now valid.
2013-07-29 15:25:05| 477.5| 0.0|INFORM|Reconstructing polygons (geometry)...
Best answer by takashi
hmm... sorry, I'm not sure what's going on. How about testing with a simple data? For example:
  If the SliverRemover works with a test data like this, there may be problems in the actual data. You should validate the data more carefully.
Otherwise, I recommend you to contact Safe support.   Takashi
  • July 29, 2013
see the print screen here: http://oi41.tinypic.com/mtxwdv.jpg
  • July 30, 2013
Quote from the help of the SliverRemover:
This transformer requires clean, valid data. For example, self-intersecting, or degenerate polygons will not be properly repaired.   So, when input polygons are not clean, the SliverRemover may not generate results. If you don't use FAILED ports of the GeometryValidators, does the SliverRemover work?
Takashi
  • July 30, 2013
Good day Takashi,
Unfortunately, even after disconnecting the FAILED port of GeometryValidators, there is nothing different, no output.
Worst, I tryed connecting the Input directly in the transformer and no more result. Even with another dataset, I dont get output.
I am fearing the problem could be in my FME system settings. I am using FME 2013 SP2 32bit on a windows 7 64bit computer.
Looking more carefully in the log I have found something anormal just before the translation stop:
2013-07-30 08:23:19| 0.3| 0.0|INFORM|Loaded module 'SliverRemovingFactory' from file 'C:\\apps\\FME\\plugins/SliverRemovingFactory.dll'
2013-07-30 08:23:19| 0.3| 0.0|INFORM|FME API version of module 'SliverRemovingFactory' matches current internal version (3.7 20121025)
2013-07-30 08:23:19| 0.3| 0.0|INFORM|FME Configuration: Source coordinate system for reader MAPINFO_1[MAPINFO] set to `LL-WGS84' as read from input data
2013-07-30 08:23:19| 0.3| 0.0|INFORM|Coordinate System `LL-WGS84' parameters: CS_NAME=`LL-WGS84' DESC_NM=`WGS84 Lat/Longs' DT_NAME=`WGS84' GROUP=`LL' MAP_SCL=`1' PROJ=`LL' QUAD=`1' SCL_RED=`1' UNIT=`DEGREE'
2013-07-30 08:30:16| 434.3|434.0|INFORM|Emptying factory pipeline
2013-07-30 08:30:16| 434.3| 0.0|STATS |Unexpected Input Remover(TestFactory): Tested 1289 input feature(s) -- 1289 feature(s) passed and 0 feature(s) failed
2013-07-30 08:30:16| 434.3| 0.0|STATS |Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2013-07-30 08:30:16| 434.3| 0.0|STATS |Source -> Generic(TeeFactory): Cloned 1289 input feature(s) into 1289 output feature(s)
2013-07-30 08:30:16| 434.3| 0.0|STATS |Mun Feature Counter -1 18(TeeFactory): Cloned 1289 input feature(s) into 1289 output feature(s)
2013-07-30 08:30:16| 434.3| 0.0|STATS |Secteurs_Franco (MAPINFO_1) Splitter(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2013-07-30 08:30:16| 434.3| 0.0|INFORM|Tagging...
2013-07-30 08:30:50| 468.2| 33.9|INFORM|Tagging done (34 s).
2013-07-30 08:30:50| 468.2| 0.0|INFORM|Repairing...
2013-07-30 08:30:50| 468.2| 0.0|INFORM|Repair successful (0 s). All polygons are now valid.
2013-07-30 08:30:50| 468.2| 0.0|INFORM|Reconstructing polygons (geometry)...
  • July 30, 2013
  • July 31, 2013
The transformer is working with the simple geometry output. I suppose there is a problem with my data but I have use geometryValidator on it and it's supposed to be clean now. Anyhow, what is the use of the SliverRemover if you need a perfect dataset in input.
I have contact Safe support and Im waiting for a feed back.
Thank you for your support Takashi
  • August 1, 2013
The problem was that in fact that the input data was aggregate. I use de deaggregator and the translation finished successfuly.
It seems that many transformers cannot procceed when data are aggregate or contain donut holes.
