Sketchup Layers
  • November 16, 2012
  • 125 views
I am using FME to write a Sketchup files with a combination of different elements.  Is there a way to define layers with FME in a sketchup file?
I examined a sketchup file with layers using the logger in FME and it looks like the GeometryTrait "sketchup_layer_name" is used define the layer of the object.  But when I add this attribute to my translation the objects are not placed on different layers.  They all still end up on Layer 0.
Best answer by conterrauta
The layername is stored in the GeometryTrait.
You can set it with the GeometryPropertySetter.
Kind regards
Uta
  • November 18, 2012
Kind regards
Uta
