Simplifying a Table
  • September 4, 2017
  • 5 replies
  • 108 views
Hi folks I have this table:
and trying to simplify it so I can get to this:
Any help greatly appreciated.
Omar
Best answer by david_r
Here's one way to do it, I'm sure there are others:
  1. ListPopulator with prefix set to "Segment", list name as "SegmentID"
  2. ListExploder on list "SegmentID{}"
Send the attributes "ReportID" and "SegmentID" to your writer
  • September 4, 2017
fmelizard
Forum|alt.badge.img+22
  • September 5, 2017
What is the source format? I'm a bit concerned that the reader will be a bit confused at having several columns with the same name. I checked and the CSV reader will add a suffix to duplicated column names so that is a way in. And then @david_r's technique works swimmingly.
  • September 5, 2017
I tested with multiple identically named columns in Excel and FME was kind enough to suffix them for me, as I imagine it does for CSV:
Segment
Segment00
Segment01
Segment02
Segment03
Slightly confusing that the first occurrence isn't numbered, but the ListPopulator seems clever enough to take that into account, so no sweat.
  • September 5, 2017
Thanks @david_r
Once again FME delivering brilliant support, I really like this product and the community!
As an aside, I was getting a lot of `MISSING_PARAMETER_LIST' rejections on the ListExpldoer as my lists were not all the same length and contained missing records. I realised that by importing the CSV and reading blank cells as 'NULL' rather than 'missing' I was not getting any `MISSING_PARAMETER_LIST'. on my ListExploder.
Once I exploded the list I filtered out the NULL records.
This is the value I set in the reader.
  • September 5, 2017
Thanks @david_r
Great to hear you got it to work and thanks for letting us all know about this important detail.
