shortest path finder with turns restriction
  • April 22, 2015
  • 52 views
Problem: Using FME and a road networks dataset, I am trying to find the shortest path from A to B, while taking into consideration of turning width (say for a truck). I have created a point feature class which contains all the turns/junctions, each of these junctions will have a maximum allowed turning width. How would I incorporate this into my shortest path finder analysis?
Example Scenario: A truck needs to travel on certain roads with certain restrictions, and can only turn at intersections wide enough to accommodate the truck.
I have used FME to select all the roads that satisfy the criteria (i.e. clearance height, maximum weight, shortest length traveled), but how would I incorporate the turns restrictions (turn width)from another feature class?
Thanks very much for any input, below is a screenshot of my FME workbench.
Best answer by gio
By using the truning width in a grouping strtegy (groupBY) for instance?
gio
Forum|alt.badge.img+15
  • April 24, 2015
