Shorten line by fixed distance
  • September 5, 2016
  • 299 views
Dear All ,
I used sniper to shorten lines from both the beginning and ending location but it is not working , I used -10 for beginning and @Length()-10 for ending , may I know what might be the problem .
Thanks ,
Best answer by david_r
I just tested the following using FME 2016.1:
The result:
Which version of FME are you using?
Forum|alt.badge.img+63
Use 10 for the beginning instead of -10
  • September 5, 2016
The result:
Sorry My bad the line was very long and reduce 10 was not showing any different , snipper works fine
