Shapefile Writer: The keyword DIMENSION has an incorrect value: 'char(254)'. The value must be one of: AUTO, 2D, 2DM, 3DM
  • Dec 13, 2022 11:14 AM UTC
  • 50 views
i have dragged and dropped a LL27 shapefile on to Fme workbench 2020.2. Then I add a writer. Set the output dimension as 2D and coord system as TX-S. Running this is giving the error as above.
The same workflow runs without errors in FME workbench 2017.1 In fact I do not have to set any dimension in 2017.1 The simple coordinate conversion from LL27 to TX-S runs normally.
Wondering what I need to tweak out here in 2020.2 to get the same result
itsmatt
Forum|alt.badge.img+48
  • Dec 14, 2022 10:37 AM UTC
Do you have an attribute in your data called DIMENSION?
How are you setting the dimension? seems weird indeed
