I was wondering if anyone has got any experience with setting Appearances within FME?
I am in the process of converting an OS MasterMap Topo Layer ESRI Shape file, that has been converted to 3D (so, it has 3D vertices instead of 2D) to a Wavefront Obj file and want to style the resultant Obj file according to attribution contained within the file (these are the Descriptive Group/Term attributes).
According to the Safe website, you need to create a new null geometry object using the Creator Transformer, you then create a new style using the AppearanceStyler transformer and you then add this style to your geometry using the AppearanceSetter transformer (previously called the AppearanceAdder). Unfortunately, nothing seems to happen. I get my Obj file, but there are no appearances created. Does anyone have any ideas why this might be?
cheers
Dave
