set the SDF 'Has Elevation' (true/false)
  • Aug 22, 2022 12:06 PM UTC
  • 27 views
rudewi
Participant
If I write to SDF the 'Has Elevation' of the schema seems to be on 'false' by default. My data has geometry with Z values, wich are visible if i open the SDF file in the data inspector. But the SDF schema stays on 'Has Elevation = False', wich means the Z value isn't shown in autocad map3D. How can I change this?
evieatsafe
Forum|alt.badge.img+28
  • Sep 6, 2022 9:40 PM UTC
Hi @rudewi​ thanks for your question; however I need some clarity before being able to answer:
  • There is no 'has elevation' option I am aware of in FME, where is this being observed? Could you provide a screenshot?
  • What version of FME are you using?
  • Is the output SDF file readable in FME with Z values?
Cheers, Evie
