Set SDO_GTYPE for geometry?
  • July 1, 2013
  • 62 views
   Is there any way to set SDO_GTYPE to a particular value( say 2006) for all feature geometries?
Subrat.
Best answer by david_r
is there any particular reason you need to do this? The SDO_GTYPE is normally a function of the properties of the geometry, not the other way around.
I guess you've already looked at the spec for this value?
For a geometry type 2006 you could perhaps use a combination of a 2DForcer,  a MeasureRemover and a GeometryFilter.
David
  • July 1, 2013
David
