Sequence of output on ports on FeatureReader ?
  • Nov 3, 2021 12:14 PM UTC
  • 5 replies
  • 85 views
lifalin2016
Forum|alt.badge.img+42
A FeatureReader typically outputs data features on defined data ports, plus the "<Schema>" and "<Initiator>" ports.
I know that "<Schema>" features gets output before any data features (from that schema), but what about "<Initiator>" ?
Does this feature get output at the very end, i.e. after all data (for this initiator) has been output ?
If not, is there a way to initiate a downstream transformer _after_ all data has been output ?
Best answer by jdh
The initiator is output last, that's the only way it can have a valid _matched_records attribute.
nielsgerrits
Forum|alt.badge.img+67
The way I do this is by putting all features through a Sampler and set it to last 1.
lifalin2016
  • Nov 3, 2021 12:34 PM UTC
I tried and attached loggers to the "<Initiator>" port and all data ports.
It does seem, that the "initiator" feature is logged last, although this is only determined by its position in the log, not the (identical) timestamps.
lifalin2016
Plan B :-)
jdh
Forum|alt.badge.img+41
  • Nov 3, 2021 7:14 PM UTC
lifalin2016
  • Nov 4, 2021 8:06 AM UTC
Excellent point.
