Separate address values in a single field on left and right side of "/" separator to a new field
  • Oct 21, 2022 9:42 PM UTC
  • 86 views
vxn43
Forum|alt.badge.img+20
I have a table of addresses with these values in a single field, example: Main St/Carter Ave. I want to put Main St in a new field named StreetName, and Carter Ave in a new field named IntStreetName. I know there must be a method for parsing the values to the left and right of the "/" separator. How can I do this in FME?
I know how to do this in python using split. I am new to FME.
Best answer by geomancer
There are many ways of accomplishing this in FME.
Use an AttributeSplitter to create a list, followed by an AttributeManager to extract the list values to attributes.
Or use regular expressions in an AttributeManager.
Split_AdressesIf you want to, you can even do it in Python, using a PythonCaller.
geomancer
Forum|alt.badge.img+71
  • Oct 24, 2022 8:14 AM UTC
