Selection with Python in gdb Reader
  • Nov 23, 2023 11:17 AM UTC
  • 100 views
marta.podsiad
Forum|alt.badge.img+12
I am struggling to put a simple Python script in gdb Reader/Scripted Parameter Value that will allow me to read only polyline. Could someone please push me in the right direction?
  • Nov 23, 2023 11:58 AM UTC
You can't assign anything to parameter values with Python, you can only read them. This is because the Python code is evaluated at run-time, when the parameter values are frozen.
marta.podsiad
  • Nov 23, 2023 1:51 PM UTC
In this case how I can read only relationship types from gdb without reading all data?
j.botterill
Forum|alt.badge.img+69
  • Nov 24, 2023 1:07 AM UTC
Hi Marta, I think you may need to change the Geodatabase Reader feature type to read a specific geometry type and/or expose "Format Attributes" . Refer to this article Introduction to Working with Geodatabase Relationship Classes (safe.com) #ReadingRelationshipClasses, appears to be some attachment workspace examples there
marta.podsiad
  • Nov 24, 2023 9:58 AM UTC
I have tested that before I posted the question. relationship type does not have schema so feature reader is not going to help I am affraid
