Select first instance of the hour for a given date
  • Jun 8, 2023 11:25 PM UTC
  • 42 views
ldupont
Hi FME,
I have a dataset with date/time stamps where I need to retain only the first occurrence in each hour, on a given day.
For example:
1/1/2000 12:05 --> Keep
1/1/2000 12:10 --> Discard
1/2/2000 12:05 --> Keep
1/2/2000 12:15 --> Discard
1/2/2000 12:59 --> Discard
1/3/2000 12:00 --> Keep
1/3/2000 12:12 --> Discard
Thanks for taking a look!
geomancer
Forum|alt.badge.img+71
  • Jun 9, 2023 7:33 AM UTC
Split the date/time step on the space.
Pass the results to a sampler, sample only the first feature, group by date.
This will sample only the first feature entering for each date.
Split_Date_Time
geomancer
  • Jun 9, 2023 10:39 AM UTC
Update.
Your example doesn't show more than one hour per date, but your description does hint at that.
If you want something like
1/1/2000 13:05 --> Keep
1/1/2000 13:15 --> Discard
the solution presented above will not work.
In that case you can split on ':'
