Search Envelope value changes depending on the filter
  • Mar 10, 2020 12:24 PM UTC
  • 59 views
jugoslaviaa
I have polygon datasets, where I would like to filter one object based on id and I would like to set the parameter of Search Envelope based on this filtered object. I will extract the bbox of the polygon. How can I pass these values to Search Envelope?
Thanks in advance.
Best,
N
itay
Forum|alt.badge.img+19
  • Mar 10, 2020 4:03 PM UTC
I would read in the polygon, use a tester to remain with selected by ID (in case you cannot do that directly in the reader) and use selected as initiator for a FeatureReader transformer.
jugoslaviaa
  • Mar 11, 2020 8:46 AM UTC
FeatureReader is a good solution for it. However, I really want to do it via Search Envelope.
