Schemamapper error
  • August 9, 2017
  • 53 views
Forum|alt.badge.img+63
If somebody from Safe's support could take a look at this.
As mentioned in this thread the SchemaMapper is showing some odd behaviour. I'm doing a simple attribute map and specify that the old attributes should be removed. However, they remain and the new ones aren't automatically exposed.
Sample template attached:
fmelizard
Forum|alt.badge.img+22
  • August 9, 2017
Hi @redgeographics. I'm looking into the SchemaMapper behaviour. For new attributes, there is a Known Issue # 31149 to expose attributes created by the SchemaMapper. So I'll add more interest to that.
For Source Attribute parameter, I'm continuing to investigate. Thanks!
fmelizard
  • August 10, 2017
Hi @redgeographics. For source attributes being displayed when Source Attribute parameter is set to Remove, I filed known issue # 78972. I'll update the question and add in any updates as I hear from Development.
Thanks Natalie!
