Right location, wrong scale for vector features
  • Jun 8, 2022 11:56 AM UTC
  • 60 views
I have converted a DWG layer to shapefile and am in the process of trying to georeference it. I have used the AffineWarper to get the data to the correct location but the scale is too big and I need to reduce it. When using the Scaler it changes the location. I then used the Offsetter but it does not place the features where I need them either!
Any help would be much appreciated 🙂
Screenshot shows process after AffineWarper with features in right location but with wrong scale.Screenshot 2022-06-08 123628
Forum|alt.badge.img+63
The Scaler can work in relation to the 0,0 point of the coordinate or the centerpoint of the data (via the Scale Origin parameter). When you say the data is in the correct location, how did you determine that?
