RGB pointcloud to Hex
  • Mar 30, 2020 8:46 AM UTC
  • 104 views
gvenhorst
In a point cloud I have those values for RGB.
@Component(color_red)
@Component(color_green)
@Component(color_blue)
How do I convert this to a hex number or an FME_color atribute?
The goal is to filter the point cloud by color, for example removing all greenery from grass.
Have no inpute other than the point cloud.
Forum|alt.badge.img+54
  • Mar 30, 2020 8:59 AM UTC
There are a couple of custom transformers that could help you here - ColorConverter or ColorCalculator
gvenhorst
  • Mar 30, 2020 9:17 AM UTC
I tried but I can't get this set up properly with these 3 components. The tools expect 1 component
  • Mar 30, 2020 9:30 AM UTC
The color calculator will allow you to use the text editor as input so you can structure it like this
Although, looking at your question again, I presume you actually want to do the calculation on each pixel within the point cloud?
gvenhorst
  • Mar 30, 2020 9:49 AM UTC
@Value(@Component(color_red)),@Value(@Component(color_green)),@Value(@Component(color_blue))
Error : Unknown color format
