rgb channel order
  • Jan 26, 2018 5:02 PM UTC
  • 67 views
gio
Forum|alt.badge.img+15
Hi all,
Upon creating rgb values it appears that the lueb and green channel are reversed.
When I create the values with an expression evaluator and set them on objects (linear), the gradient is correct.
In the raster however the blue and green are reversed. (swapping green and blue channel values corrects this)
Is my observation correct? Is this intended?
jdh
Forum|alt.badge.img+41
  • Jan 26, 2018 5:06 PM UTC
I can't say I've observed this. What software are you using the view the raster?
gio
  • Jan 26, 2018 5:11 PM UTC
@jdh
Datainspector.
I'll post a pic of the expressions next week, gottogo. Before they lock me up. I'm about the last here...
Fiddling with FME is fun...;)
Workspace is working correctly. Had to swap the channels though.
Happy Weekend!
