Request for Workspace to process recursive json file
  • Mar 23, 2017 3:10 PM UTC
  • 5 replies
  • 85 views
I need help to process json file and write it out in csv. Thanks.
Best answer by david_r
Did you try simply creating a JSON reader and point at your URL? When I do, I get the following reader definition:
You can then simply use a ListExploder on "response{}" and you should be good to go. You can also use the BulkAttributeRenamer in "Remove prefix string" mode to fix up your attribute names, if necessary. Example result after having removed the prefix "0."
itay
Forum|alt.badge.img+19
  • Mar 23, 2017 3:18 PM UTC
Ctrl+G and see where you end up...
  • Mar 23, 2017 3:29 PM UTC
Can you please be elaborate? Thanks
  • Mar 23, 2017 3:37 PM UTC
itay
  • Mar 23, 2017 4:35 PM UTC
Thats the shortcut in the Workbench application to generate a workspace.
This will open a wizard that requires you to input the reader format and location (your url) and writer format and destination.
What @david_r suggests can help you 'clean' the content to a better result.
  • Mar 24, 2017 10:27 AM UTC
Thanks David. This is what I got. Please enlighten me further. Its not showing what yours are showing. All I did is in the image attached. Thanks as I await your support.
@david_r
