Replicating ArcGIS “Locate features along route”
  • Mar 30, 2019 10:53 AM UTC
  • 195 views
Does anyone know of a way to replicate ArcGIS “Locate features along route” functionality?
Specifically, I have a network shapefile (polylines) and a separate polygon shapefile. I am wanting to know which lines are contained within which polygons and for the lines that are partially contained within the polygons, I want to know the start and end length in metres (from direction of travel) along the lines that the polygon intersects.
Thank you in advance.
danilo_fme
Forum|alt.badge.img+58
  • Mar 31, 2019 12:46 PM UTC
Hello @sideshowt
I suggest you to use the transformer LineOnAreaOverlayer to check the lines inside Polygons
Thanks,
Danilo
  • Apr 1, 2019 7:34 AM UTC
Before using the LineOnAreaOverlayer, you could use a MeasureGenerator to generate measures on each line. That way you can use the MeasureExtractor after the LineOnAreaOverlayer to get the start and end values for each intersection.
