ReplaceRegularExpression syntax
  • May 9, 2022 6:15 AM UTC
  • 1486 views
Hi, I am trying to use ReplaceRegularExpression as described here:
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/!Transformer_Parameters/StringFunctions.htm
To do a simple transformation of Quotes to escaped Quotes in strings.
I have the following:
@ReplaceRegularExpression(@Value(Description),["],"\\\\""",FALSE)
(as the instructions say I need to add quotes and escape the quote in the to expression.)
This does not work, but at least does not have errors.
If I try to slightly change the syntax of the to expression (eg less quotes) I get serious errors...
Any ideas welcome...
Best answer by nielsgerrits
I tried a bit and
@ReplaceRegularExpression(@Value(Description),\",\\",caseSensitive=TRUE)
seems to work for me. As an alternative you can also use the StringReplacer set to Regular Expression replacing " with \\".
nielsgerrits
Forum|alt.badge.img+67
I tried a bit and
  • May 9, 2022 6:48 AM UTC
I tried a bit and
Many thanks...that seems to work fine now.....
