replace substrings based on a lookup table
  • Oct 1, 2024 4:45 AM UTC
  • 174 views
pkno
Forum|alt.badge.img+5
I am trying to find a functionality within FME that allows me to replace substrings based on a lookup table. Since I have several hundred mappings, chaining string replacers together isn’t really an option.
Basically something like an AttributeValueMapper that looks at substrings instead of the whole value only or a string replacer that accepts multiple string/replacement inputs.
Is there such a transformer or any workaround to do this?
Thank you!
pkno
  • Oct 1, 2024 5:12 AM UTC
nevermind, found the StringPairReplacer
Forum|alt.badge.img+54
  • Oct 1, 2024 3:04 PM UTC
I've used an inlinequerier to do this in the past which allows lookups to be maintained in a table outside of the workspace
pkno
  • Nov 12, 2024 12:27 PM UTC
Can you share your sql script? I am trying to switch over to a dynamic solution using an external lookup table as well.
