RegExp in StringSearcher: Result does not match?
  • Jun 10, 2020 7:53 AM UTC
  • 5 replies
  • 88 views
jayqueue
Hello,
I'm trying to read an OCRd pdf_text attribute and get the text between 2 lines.
My regexp is
(?=Detail : Verbruik vaste telefonie ).*(?=Detail : Verbruik mobiele telefonie )
but my result is strange
It does not end on "Detail : Verbruik Mobiele telefonie". Is there an error in the RegExp?
Best answer by ebygomm
No, the regex you have is greedy, it will match as much as possible. You will need different regex if you want to match just down to the first instance of "Detail : Verbruik mobiele telefonie"
try
(?<=Detail : Verbruik vaste telefonie ).*?(?=Detail : Verbruik mobiele telefonie )
If you actually want to include the first Detail : Verbruik vaste telefonie in your matched group I'd probably use this instead
Detail : Verbruik vaste telefonie.*?(?=Detail : Verbruik mobiele telefonie )
itsmatt
Forum|alt.badge.img+48
  • Jun 10, 2020 8:07 AM UTC
Hmm, it could be an issue with the preview window. Do you get the same result when just running the workspace?
Maybe there is a limit to the size of the matched string. 255 characters or something. Can you try using the '<' to match multiple strings and get a list?
(?<=Detail : Verbruik vaste telefonie ).*(?=Detail : Verbruik mobiele telefonie )
jayqueue
  • Jun 10, 2020 8:23 AM UTC
@virtualcitymatt,
Think it's a preview issue, output is not cut off.
However, it selects too much. It should end on the first 'Detail : Verbruik mobiele telefonie', no?
Forum|alt.badge.img+54
  • Jun 10, 2020 8:26 AM UTC
@virtualcitymatt,
try
try
jayqueue
  • Jun 10, 2020 8:36 AM UTC
try
I feel so stupid. I really overlooked the greedy part.
Thank you so much!
