Reclassification of class attribute (LiDAR) with FME
  • Feb 6, 2018 7:31 PM UTC
  • 6 replies
  • 155 views
Hello FME-Community,
I am working with FME desktop 2017 and LiDAR point clouds. I have selected a certain number of LiDAR points that intersect with a polygon (shape). All these points belong to class 5 (tall vegetation), but I would like to reclassify them as class 6 (buildings).
I have not been able to find any tool that makes this reclassification. Could you help me or give me an idea?Thank you very much.
danilo_fme
Forum|alt.badge.img+58
  • Feb 10, 2018 8:00 PM UTC
Hello @cesar_vicente, how are you?
Did you watch this Webinar ? How to get the most out of lidar data
I believe there are interesting Workspaces and slides about the Lidar.
Thanks,
Danilo
  • Feb 11, 2018 3:33 PM UTC
Hi @cesar_vicente, have a look at the PointCloudExpressionEvaluator.
Hello @takashi. PointCloudExpressionEvaluator performs the reclassification of LiDAR points just as I want. Perfect However, now I have another difficulty. I have already reclassified the class 5 points in class 6. These points I have obtained from trimming the point cloud with a polygon (with clipper transformer). Now I want to collect the reclassified points with the original point cloud. I tried with PointCloudMerger transformer, but I can not join the points and get the same number of points as the initial point cloud.
Is it possible that there is another tool to do this process? Or maybe there is a tool that allows you to make a selection of points (class 5) from a polygon and without the need to make a clip? If my explanation is not correct, I can explain again.
Thank you very much for your help and your time.
Thanks,
Danilo
Hello @danilo_fme. Thank you very much for your suggestion. I will see it enchanted.
danilo_fme
  • Feb 12, 2018 8:28 PM UTC
Great @cesar_vicente !
  • Feb 13, 2018 10:53 AM UTC
If the requirement is to merge two or more point cloud features into a single point cloud, the PointCloudCombiner might help you.
