Reading DWG with 2 transformers
  • Apr 26, 2024 7:35 AM UTC
  • 106 views
jkr_wrk
Forum|alt.badge.img+37
At this moment I received a DWG drawing with both Extended and Object data. To convert this data I first have to read with:
Autodesk AutoCAD Civil 3D
then read with
Autodesk AutoCAD Map 3D Object Data
and merge all features on the autocad_entity_handle
Β
Am I doing something wrong or is this the only way to get both attributes?
Is it possible build a transformer that uses both reading engines because I think that would make the reader faster than current.
Best answer by ali-safe
Hello,Β @jkr_wrk.
Thanks for your question. As of now, that isΒ the only way.
The Map Object data is built on the Autodesk-supplied RealDWG reader while the Civil 3D reader is built on the ODA-supplied reader. So, they are using two completely different libraries to read the same file.
We are looking into if this current process can be tweaked/enhanced: (FMEENGINE-82673).
ali-safe
Forum|alt.badge.img+24
  • Apr 30, 2024 6:18 PM UTC
Hello,Β @jkr_wrk.
