Read a file containing user variables
  • Apr 24, 2020 2:57 PM UTC
  • 96 views
I'd like to read a text file containing several lines of user defined variables given in the following format:
var_name = "var value"
There are many lines, each one contains one single variable with one single value:
var_name0 = "var value0"
var_name1 = "var value1"
I read the text file using an AttributeFileReader to which I connected an AttributeSplitter.
My results come as one single concatenated line which is obviously not what I want.
In the Delimiter field of the latter, I tried inserting `\n` `\r` or`\r\n` without any success.
I also tried inserting a single newline by pressing one time enter in the "Editor" as discussed here (2013):
https://knowledge.safe.com/questions/2361/use-attributesplitter-with-a-carriage-return.html without much success.
I'm using FME(R) 2020.0.0.1 (20200316 - Build 20202 - linux-x64) on Ubuntu 18.04.
Thanks.
erik_jan
Forum|alt.badge.img+26
  • Apr 24, 2020 3:13 PM UTC
I would try reading the file line by line.
Then pick each line apart, setting the attribute name and attribute value, using AttributeSplitter, delimited by '='.
Finally using Aggregator to get all attributes in one feature.
Hope this helps.
jdh
Forum|alt.badge.img+41
  • Apr 24, 2020 4:25 PM UTC
What @eric_jan said, though I would probably create an attribute from the results of the attribute splitter before aggregating.
That said, if you have any control over the user variable file, making it a CSV would be easier to work with directly in FME.
