RCaller
  • Jun 7, 2024 7:19 AM UTC
  • 5 replies
  • 359 views
kardemummabulle
Forum|alt.badge.img+3
Hello,
I have a general question regarding the RCaller. I have been actively coding in R over past 10 years, and started playing with integrating my code into FME for automating some of the analyses about a year ago, but what bothers me most is that FME is always putting up a fight whenever facing more complex custom R functions, i.e. loops, advanced raster processing involving raster lists/stacks, LiDAR, etc. It is always a problem when trying to get FME recognize the results as fmeOutput, and it is just never easy compared to how other things work in FME...
It just seems like the RCaller is so basic in FME, rudimental even, not allowing no unleash the full R potential within the FME environment. Hence is my question to you, have you guys considered developing it further or is it because nobody is really interested in using R inside FME? Or is it just my subjective opinion and I am basically missing something? :)
@dmitribagh
Thanks in advance.
-Sveta
felipeverdu
Forum|alt.badge.img+12
  • Jun 10, 2024 2:17 PM UTC
Hi @kardemummabulle
You raise an interesting question! I hope that anyone from safe  @dmitribagh , @markatsafe @debbiatsafe can comment on this
BR
Felipe Verdú
dmitribagh
Forum|alt.badge.img+20
  • Jun 10, 2024 5:09 PM UTC
Hi @kardemummabulle,
I had a lot of fun playing with some R libraries such as rayshader, rayrender, brickr, even raybonsai, and my main struggle was inability to use snippets generated in other places of a workspace for inclusion and execution inside the RCaller. It really feels like not that many people are interested in using R with FME - I never heard back from anybody after all my demos, presentations, and tweets about R integration. Maybe it’s because we have so many Python fans in the FME Universe?
In order to move the R integration forward, we need to hear from you, our customers, that you need it - with enough demand, we can begin working on the necessary improvements.
Dmitri
kardemummabulle
Hi @dmitribagh,
Thanks on following up on my question. I would guess that Python wins in terms of number of fans and users, and it is so much easier with Python in FME compared to R, so I am not surprised at all that RCaller and PythonCaller are at totally different levels :) It is just way easier to do exact same thing in Python I assume...
I feel like just making FME recognize output from R in a simple manner would be a tremendous improvement. Something like:
fmeOutput=dataset # dataset being the output of R
without explicitly telling FME in advance if it is a dataframe, a raster, raster list or whatever… There is gotta be a way to make it happen, I think :)
-Sveta
dmitribagh
  • Jun 18, 2024 7:42 PM UTC
How do you get around the limitations now?I checked my R scripts (I didn’t touch R for 5 years, and don’t have all the details on top of my head), and found that I was generating a temp path, which I was passing to the script, which saved the results, and then I used FeatureReader to bring the result back into FME. Not the most optimal way, but it worked for me.
Dmitri
kardemummabulle
Hi @dmitribagh,
That would be the easiest workaround I guess. This solution works, but as you mentioned it is not optimal if one for example wants to continue with the workflow and have a more or less connected pipeline…
The last thing I have done with raster list output from R is writing the path and explicitly telling FME that fmeOutput contains 4 rasters (kindly see picture attached). Then you can sort of continue your analysis, like with CoordinateSystemSetter in my example (though it is also a question why FME lost the projection that I set in my R script🤷🏻 which works otherwise in R or RStudio), and FeatureReader and so on… It took a bit of time to make this work and FME really did not want to cooperate (mostly because I was not really understanding what it wanted; I know R (I think), but I don’t really know FME that well) :)
If this is something that can be solved in a more elegant way in FME or if there is way to make FME and R communicate with each other better than they do now, then I think it would be so much easier to integrate more complex R-based analyses inside FME…
With Posit growing so fast, R has really developed a lot over past few years (Markdown, Quatro, Shiny, all the hyped packages for geospatial analysis)… Just imagine how cool it can be if R and FME were compatible… Btw regarding compatibility, currently to make FME “accept” output from R that contains more than 1 cell and 1 row, one needs to have R version 4.1.3, which is like a “prehistoric” version of R, from 2022 or so… There is a potential for improvements for sure, the question is if Safe wants to continue with RCaller and to develop it further…
