RasterExtractor duplicating one blob value for all input feature types
  • Nov 18, 2024 9:07 AM UTC
  • 129 views
aaronp_osni
Forum|alt.badge.img+4
Hi folks,
I have multiple images I need to extract blob data for. When I input my individual feature types into the Raster Extractor (eg. 32 JPEGs, as shown in image below) the raster extractor seems to duplicate the first image for all of the feature types, so I end up with a blob of the first image for all of my individual feature types:
This results in the first image duplicated, as a blob, for all 32 features - when I require a unique blob value for each input feature. The only workaround I’ve found is to have a raster extractor for each feature type, which is not suitable.
Any help is greatly appreciated.
Kind regards,
Aaron
Best answer by hkingsbury
Are you sure they’re all the same? the first (and possibly last) section of the blobs will very possibly be the same (due to the same file format) but the core of the blob will be different
Additionally, having separate readers for all you images is a pretty inefficient way of reading in the data, i’d recommend using a wildcard
http://docs.safe.com/fme/2013/html/FME_QuickTranslator/content/fme%20configuration/dataset_wildcards.htm
hkingsbury
Forum|alt.badge.img+73
  • Nov 18, 2024 7:12 PM UTC
aaronp_osni
  • Nov 22, 2024 11:44 AM UTC
Thanks so much. Yes, it turns out the blobs were unique. I used a duplicate filter to determine this. However, in the visual preview the same image was displaying for each record. This led me to believe the image was being duplicated. And yes, the first and last part of the blob was the same!
Also, I’ve now used a JPEG reader and merged the feature types. This is a lot more efficient. The reason I didn’t do this before was because the same image displays for each record. I don’t trust the visual preview anymore!
