RasterExpression
  • Jan 24, 2018 4:51 PM UTC
  • 115 views
gio
Forum|alt.badge.img+15
Trying to get some calculations done.
But as soon is the band and the attributes are combined the calculation fails.
The pic shows the expressions.
The first 2 get a values rest drop to No Data.
Tried rounding using int8, 16 etc. , ceiling. Every time same result.
Tried different interpretations.
The input is a DEM; min= 0 and max 519 (Real64)
Any tips on this?
The calculation is a non-iterative variant for gradients. These work neatly in python script I made (did not invent the calculations , mind you)
tx for any thoughts!
Best answer by takashi
Hi @gio, the RasterExpressionEvaluator could generate unexpected results if the input raster had Nodata definition. If the input raster has Nodata, try removing the Nodata with RasterBandNodataRemover beforehand.
jdh
Forum|alt.badge.img+41
  • Jan 24, 2018 5:45 PM UTC
From the image you're going from a DEM in the range of 0-519 and casting (bounded) it to an int8 (-128-127) and then casting it again to grey8 (0-255)? But then how is the min-max range 255? Was the interperetationCoercer set to UINT8 when you got the inspector results?
What purpose does the RasterSelector serve? The RasterInterpretaionCoercer forces the raster to a single band, and the RasterExpressionEvaluator does not take into account band selection regardless.
I'm also not able to replicate your issues.
Does your source data have a NoDataValue set?
  • Jan 25, 2018 1:28 AM UTC
gio
  • Jan 25, 2018 10:45 AM UTC
@takashi
Way to go Takashi!
Removing the Nodata solved it!
That was indeed the problem.
Thanks!
Arigat?gozaimashita (I hope it is correctly written )
  • Jan 25, 2018 11:18 AM UTC
@takashi
Way to go Takashi!
Thanks!
Correct, but just "Arigato" is more friendly :-)
Formal and informal. Maybe similar to the difference between "Alstublieft" and "Alsjeblieft".
