rasterbandseparator
franco69
Forum|alt.badge.img+11
Hi Guys,
next mission:
I have raster (Network Common Data Format) and let it through the RasterBandSeparator and he gives me 12 different rasters (monthly)....to combine them again in one....thats no problem but to get the summary of the monthly values and write them in an attribute? (i don't find them)
It's a question from one of my colleagues...I'm not so familiar with raster data.
Greetz
Franco
franco69
  • March 26, 2015
first question was not so clear i think
i have NETCDF Raster and separate the bands through a rasterbandseparator...
gives me 12 different bands....when i combine that with aRAsterBandCombiner and i take a raster point it gives me 12 different values (monthly)  BAND01(REAL32) 102.34, BAND02(REAL32) 102.66, etc...
how can I take these values and summarize them in a yearly value?
Greetz
Franco
  • March 26, 2015
if you always have 12 (or any fixed number of) bands, you can use a RasterExpressionEvaluator:
David
franco69
  • March 26, 2015
Hi David,
the A stands for?....a variable?...because when i click on a raster point info after combiner the exactly term is Band 1 (REAL32) 10.24, Band 1 (REAL32) 22,34...etc..
so i can use "A" or should i use "Band" for that in the ExpressionEvaluator.....becuase when i use ur term i get only one value, but i can't see if thats the sum now or any value...
GReetz
Franco
franco69
  • March 26, 2015
Hi David
sorry my fault...the A is included in the RasterExpressionEvaluator....;-)
i said I'm not familiar with that..so the sum is the right one
GReetz
Franco
gio
Forum|alt.badge.img+15
  • March 26, 2015
A stands for raster A if the mode is set to "one raster" (if you would inout like 2 rasters with mode "two rasters"  you would have A and B). The numer stands for the band.
Ad you have used a RasterBandCOmbiner you would have 1 raster, with 12 bands.
If you enter it in the input port, solo, you will have A[0] ..A[11]
That would be sum of your 12 monthly values
