Raster Sampler to band values
  • Nov 29, 2021 5:26 AM UTC
  • 67 views
deanhowell
Forum|alt.badge.img+24
Is it possible to resample a raster so the values left are one of the existing band values?
If I use the raster re-sampler with the average 16 interpolation type, I get an average of the 16 cells but what I need is the value that occurs the most in these 16 cells.
Best answer by bartjannink
With the RasterConvolver you can get the value that occurs most with the setting Operation: Majority. It doesn't change the raster size so you still need to use to RasterResampler on the output of the RasterConvolver.
  • Nov 29, 2021 8:34 AM UTC
deanhowell
  • Nov 30, 2021 6:49 AM UTC
Thanks @bartjannink​ that is exactly what I need.
