Raster band combine two rasters
  • Jun 3, 2020 4:23 PM UTC
  • 147 views
Dear all,
I need help with task. I have two rasters grom the same place: NIR 1 channel and RGB 3 channel.
I need to replace on RGB raster Red channel with NIR channel and save raster.
How can i do this?
Thank you on advance for help
  • Jun 4, 2020 5:24 AM UTC
Hi @marekszczepan, I think the RasterBandSeparator and the RasterBandCombiner could help you.
thank you for help. I have small problem, i receive error and don't know why
"fme_rejection_message' has value `Merged raster not created. Input rasters are incompatible because the coordinate of the lower left corner of the raster doesn't match'"
log.txt
  • Jun 4, 2020 12:55 PM UTC
log.txt
The RasterBandCombiner requires that all entered raster bands have exactly same resolutions and extents. I'm afraid that resolutions and/or extents of the two source rasters may not be identical.
You can extract properties of a raster with the RasterPropertyExtractor. Check the properties of the source rasters with Logger or Inspector.
log.txt
Yes, You were right it was due to not equal origin and min/max of files. I tiled one more time and now is working correct. Thanks You for your help
