question relate to how to split a cell with text and numbers
  • May 24, 2023 2:19 AM UTC
  • 53 views
Hello everyone,
I am trying to split a text with the attribute splitter. The text is formatted this way : text1 ( number1), text2 ( number2), text 3 (number3)… I want to extract only the value of the numbers to put it in another attribute.
Can you help?
Forum|alt.badge.img+54
  • May 24, 2023 8:33 AM UTC
I would use a stringsearcher to extract the numbers
If the numbers are always within brackets you could do
(?<=\()\d+
This will match all numbers that occur after an opening bracket
  • May 24, 2023 8:29 PM UTC
(?<=\()\d+
Thanks a lot it working​;)
