Question of validating "Hour"
  • Jan 31, 2022 3:36 AM UTC
  • 5 replies
  • 77 views
Hello everyone,
So I have a dataset and need to validate "Hour" format that is in OSM Opening Hours specification.
https://wiki.openstreetmap.org/wiki/Key:opening_hours/specification
I found a web site that have a lot if implemetation formats.
https://wiki.openstreetmap.org/wiki/Key:opening_hours#Implementation
However, I am not good at programming that I am not sure how to put it in FME for my checking.
It would be awesome if someone could give me a hand.
Thank you so much!
Zach
hkingsbury
Forum|alt.badge.img+73
  • Jan 31, 2022 8:03 PM UTC
@zacharylee_1204​  The OSM Opening Hours standard is definitely complex. We have found a good validation tool is the tool Java at https://openingh.openstreetmap.de/opening_hours.js/. You can down load the Javascript from this site or GitHUB. The JavaScriptCaller was deprecated in FME 2019 so instead we have hosted the javascript as a service on Amazon. I've attached an example workspace that has a custom transformer that uses this service.
​Thank you Mark. I would like to take your suggestion to use the Javascript from GitHUB. May I ask which file I should use as there are so many files in there.
Thank you.
daveatsafe
Forum|alt.badge.img+24
  • Feb 4, 2022 6:32 PM UTC
Thank you.
Hi @zacharylee_1204​,
The opening_hours.js library is designed to be used in a web app. I used the following procedure to set it up on a very small (and inexpensive) Amazon Web Services EC2 Linux instance:
To set up validation:
To start validation service:
  • ssh to instance
  • 'node validate.js' to start validation service
  • Ctrl-Z to suspend, then 'bg %1' to move the validation to background.
  • 'exit' ssh, then close terminal
To use service, send the following request:
http://<instance name>:3000/validate?hours=24/7
The service will return 'passed' for a valid opening hours string, and the opening_hours.js error details for an invalid string
Validate.js:
var express = require('express');
var app = express();
var opening_hours = require('opening_hours');
app.get('/validate', function (req, res) {
  try
    oh_string = req.query.hours;
    var test = new opening_hours(oh_string);
    res.send("passed");
  catch(err)
    res.send(err);
app.listen(3000);
Thank you.
Thank you very much! Will try it! :)
