Question about spatialRelator
  • Oct 14, 2014 7:37 PM UTC
  • 63 views
I would like to use the spatialRelator to test if a requestor intersects a candidate but excluding those where it is only the boundaries that touch the candidate.
See this image:
Thank you!
Best answer by takashi
You can control kinds of spatial relationships that should be detected with the "Tests to Perform" parameter. Try this setting to exclude the TOUCHES relation.
Tests to Perform: EQUALS OVERLAPS CONTAINS WITHIN
See also here to learn more about spatial relations
Spatial Relations Defined (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/spatialrelations.htm)
Takashi
  • Oct 15, 2014 12:39 AM UTC
Takashi
gio
Forum|alt.badge.img+15
  • Oct 15, 2014 4:06 PM UTC
In addition to testing for relations_pass-criteria = Touches, as Takashi suggests, you also need to check its cardinality:
_relationships{0}.card_line > 0
Set "calculate cardinality" = Yes.
Expose the attribute(s).
That is, if u wish to exclude objects that only touch by a point ( _relationships{0}.card_point > 0)
