python FMEUniversalReader open Oralce table
  • Oct 14, 2014 3:17 AM UTC
  • 71 views
I am trying to open an Oracle table using FME through python but I seem to
be missing something. readSchema() keeps complaining:
'The tables which are to be used for translation must be specified'
This is the code:
import fmeobjects
  reader = fmeobjects.FMEUniversalReader('ORACLE8i',False)
  parameters = ['SERVER_TYPE','ORACLE8i'
                          ,'USER_NAME','<username>'
                          ,'PASSWORD','<password>'
                          ,'WORKSPACE', 'LIVE'
                          ,'TABLELIST','<schema>.<tablename>']
  reader.open('<TNS_Name>',parameters)
  schema = reader.readSchema()
Thank you for your time!
Sirko
Best answer by david_r
I recommend you do something like this:
sourceFormat, sourceDataset, directives = fmeobjects.FMEDialog().sourcePrompt('', '', [])
print sourceFormat
print sourceDataset
print directives
This way you can use the interactive GUI dialog to construct your parameters and copy/paste them into your code. It's a lot easier to get something going this way.
David
  • Oct 14, 2014 6:57 AM UTC
print sourceFormat
print sourceDataset
print directives
David
  • Oct 14, 2014 11:57 PM UTC
Hi David,
Thank you for your response.
foo = dialog.sourcePrompt("ORACLE8i",'<TNS_Name>',parameters)
Using dialog.sourcePrompt()  was how I started to begin with. The key - value pairs I added to the parameters are derived from it but unfortunately I am still not getting any different results.
reader.readSchema() still fails like above and reader.read() returns nothing.
It would be great if someone could post an example or a link other than
http://docs.safe.com/fme/html/FME_Objects_Python_API/index.html to do some RTFM.
Cheers,
Sirko
  • Oct 15, 2014 1:57 AM UTC
OK my bad David was right, after I passed the directives to fmeobjects.FMEUniversalReader()
things went as expected so I went and did this:
def get_oracle_directive(self,layer):
        oracle_macros = {'SERVER_TYPE':'ORACLE8i','USER_NAME':self.ORACLE_USER,'PASSWORD':self.ORACLE_PASSWORD
                         ,'WORKSPACE':'','PERSISTENT_CONNECTION':'YES','SHOW_SYSTEM_TABLES':'NO'
                         ,'REMOVE_SCHEMA_QUALIFIER':'NO','READ_3D_POLYGON_AS_FACE':'NO','TABLELIST':layer
                         ,'WHERE_CLAUSE':'','PARSE_MAPINFO_SYMBOLOGY':'NO','MAPINFO_SYMBOLOGY_STYLE_COLUMN':''
                         ,'MAPINFO_SYMBOLOGY_INDEX_COLUMN':'','EXPOSE_ATTRS_GROUP':'','ORACLE8I_EXPOSE_FORMAT_ATTRS':''
                         ,'USE_SEARCH_ENVELOPE':'NO','SEARCH_ENVELOPE_MINX':'0','SEARCH_ENVELOPE_MINY':'0'
                         ,'SEARCH_ENVELOPE_MAXX':'0','SEARCH_ENVELOPE_MAXY':'0','CLIP_TO_ENVELOPE':'NO',
        directives = []
        directives.append('ORACLE8I')
        directives.append(self.ORACLE_TNS_NAME)
        directives.append('RUNTIME_MACROS')
        runtime_marcos = ''
        for o in oracle_macros:
            runtime_marcos = runtime_marcos + o + ',' + oracle_macros[o] + ','
        runtime_marcos = runtime_marcos +'_MERGE_SCHEMAS,YES'
        directives.append(runtime_marcos)
        directives.append('META_MACROS')
        meta_macros = ''
            meta_macros = meta_macros + 'Source' + o + ',' + oracle_macros[o] + ','
        meta_macros = re.sub(',$','',meta_macros)
        directives.append(meta_macros)
        directives.append('METAFILE')
        directives.append('COORDSYS')
        directives.append('')
        directives.append('IDLIST')
        directives.append(layer)
        return directives
