Published Parameter regular expression
  • June 23, 2016
  • 34 views
I have the following Regex ($(random)|IF|NOT|AND)
$(random) is a published parameter for FME Server, I want the user to be able to type any extra 'reserved' words they would require. This works fine when the $(random) parameter is populated, the problem is when it is left blank.
How can I ignore the blank published parameter when the user decides?
Best answer by david_r
One solution is to use the ParameterFetcher with a Tester to see if anyting was specified for the published parameter "random".
You then create the regex accordingly.
  • June 23, 2016
