Public parameter with Proj CRS trasformation
  • Oct 13, 2021 8:17 AM UTC
  • 77 views
davtorgh
Forum|alt.badge.img+12
Hi everyone,
I need to create a user parameter (choice with alias) that contains CRS used by ProjReprojector, but, in the parameter configuration, the CRS used by ProjReprojector aren't listed.
I'm using FME(R) 2020.2.1.0 (20201130 - Build 20806 - WIN64).
By the way, I need to use ProjReprojector because RDN2008 / UTM zone 32N isn't present in the Reprojector or CSMapReprojector list.
Thanks
stalknecht
Forum|alt.badge.img+22
  • Oct 13, 2021 8:46 AM UTC
imageIf you create the parameter from the PROJReprojector in Workbench 2021.1, then RDN2008 / UTM zone 32N will also be available in the list.
oscard
Forum|alt.badge.img+23
  • Oct 13, 2021 8:47 AM UTC
They are not lsited in the 2021 version either.
I'm afraid you will have to drop the "Choice with alias" parameter and create the user parameter directly from the ProjReprojector transformer:
proj1
davtorgh
  • Oct 20, 2021 2:04 PM UTC
Thank you ​ stalknecht and oscard,
maybe I will have to drop the "Choice with alias" at the moment. Anyway, I'm quite surprised that RDN2008 / UTM zone 32N isn't supported by Reprojector and CSMapReprojector.
