Process triggered from System Caller does not end when workspace aborted
  • Feb 25, 2019 8:41 AM UTC
  • 9 replies
  • 154 views
itsmatt
Forum|alt.badge.img+48
Hi all,
I've been playing around with the system caller, however, I've found that when I abort my FME process the process triggered using the System Caller keeps running.
Part of the problem is that I'm also using the TempPathnameCreator as the output for the called process, if I kill the FME process and the sub-process keeps running then the temp files also don't get deleted.
I have to manually kill and then delete the process
Does anyone know of a workaround for this?
  • Feb 25, 2019 9:32 AM UTC
How are you starting the child process in the SystemCaller? If you can get hold of the process id (pid) you can make FME wait for process termination using e.g. a PythonCaller.
Here's an example that takes a list of process ids (pid_list{}) and wait until they've all terminated before the trigger feature is output:
import subprocess
import timeclass
FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        while True:
            process_ids = feature.getAttribute('pid_list{}')
            subprocess_lines = [line.split() for line in subprocess.check_output("tasklist").splitlines()]
            running_process_ids = [line[1] for line in subprocess_lines if len(line) > 1]
            is_running = any(running is True for running in [i in running_process_ids for i in process_ids])
            if is_running:
                time.sleep(3)
            else:
                break
        self.pyoutput(feature)
    def close(self):
        pass
  • Feb 25, 2019 9:35 AM UTC
import subprocess
import timeclass
    def __init__(self):
        pass
        while True:
            if is_running:
                time.sleep(3)
            else:
                break
    def close(self):
        pass
The code above takes the output from the command "tasklist" and splits out the process ids. If you prefer, it's also fairly easy to make it look for the name of the executable by changing the index on line 10 above from 1 to 0:
running_process_ids = [line[0]  for ...
itsmatt
  • Feb 25, 2019 12:03 PM UTC
import subprocess
import timeclass
    def __init__(self):
        pass
        while True:
            if is_running:
                time.sleep(3)
            else:
                break
    def close(self):
        pass
Thanks @david_r,
The process is a java program where the call is something like  "java -jar '<some jar file>' -'<some parameters>'"
So the process is java.exe - I could look for and kill the pid relating to a java.exe process if, and only if, there is a single java.exe running. This might be my only option as you say, unless you know of a way to get the ProcessID for something triggered by the SystemCaller with Python...?
Ideally it would be great if there was something I'm missing in the system caller to avoid the need, but perhaps that's wishful thinking :D
  • Feb 25, 2019 12:15 PM UTC
Thanks @david_r,
It may be easier to just skip the SystemCaller and start your java app using the subprocess.Popen() function in Python: it will return the pid for you to use later on, without having to guess based on the tasklist.
itsmatt
  • Feb 25, 2019 1:43 PM UTC
Ok thanks David, I appreciate the suggestions.
Cheers
harmen_kampinga
That's also one of my issues when I trigger an executable
If the executable has run fairly , the SystemCaller won't end... it keeps running
Also when I stop the workspace running
harmen_kampinga
Another thing / question, related to this one: my batch file or my executable are finished running, but the system caller is still running. So the process in Workspace is not continuing. Is this a related problem or a new question? @david_r @virtualcitymatt ?
  • Mar 1, 2019 1:20 PM UTC
Difficult to say without knowing exactly what process you're starting, and how you're starting it...
harmen_kampinga
I'll show my developer it first, then I will get back on it
