Process list in NeighborFinder result
  • Mar 10, 2015 10:42 AM UTC
  • 83 views
Dear all,
I use a NeighborFinder to find points close to a polyline (segment). I also need to introduce a constraint on the matching: each points has an angle attribute. I then need to find for each segment the point with the same orientation as the point. I can do this with a tester, after having computed segment angle.
In my NeighborFinder, I set "Number of neighbors to find" to 5. It thus produces a list in output. Now, I am wondering how I can iterate over the list to find the point with the correct orientation (it is not always the closest candidate).
Hope you could help.
Best regards,
Asher
gio
Forum|alt.badge.img+15
  • Mar 10, 2015 12:07 PM UTC
You could
For each segment
Set  a index=0,
 max= listelementcounter
 and feed it to a listindexer within a custom loop to read the value, test value and cycle trough the index till max.
gio
  • Mar 11, 2015 5:31 PM UTC
..or keep relevant attributes and then explode the list ..
you can do test then
