Problem with "Test Clauses" in Tester Transformer
  • Oct 22, 2020 1:59 PM UTC
  • 22 views
Hi, I have a problem with the TESTER-Transformer. I test from two different sources:
2020-10-22 15_50_58-WindowI make the following TestClause:
2020-10-22 15_52_59-WindowThe left attributes contains a string:
C:\\Data\\DownloadAV\\AV_INTERLIS_DATEN\\ENTZIPPED_DATA\\http_download_1603358280779_10932\\Amtliche_Vermessung_-_Datenmodell_Schweiz_-DM01AVCH\\213-bruetten-gds.itf
and the right a value of 213:
2020-10-22 15_55_43-WindowThe Clause is looking for the value 213 in the other string. It should be correct, but it never find it. If I make the compare in the following way, it works:2020-10-22 15_58_23-WindowCould anyone help me?
thanks a lot
Forum|alt.badge.img+54
  • Oct 22, 2020 2:09 PM UTC
You need to add the pindir_indent attribute to every feature in order to use it in your test clause. At the moment the path_windows and the pindir_indent exist on different features so you won't get a correct result if you reference both of them in your test clause
