Polygons “with fill” as they appear in inspector,
  • March 8, 2014
  • 61 views
jamal
Forum|alt.badge.img+5
I’m not sure if there is a way to let polygons appear with fill in the Inspector.
For example, an inspector is connect to the landuse (polygons) but as they appear in the inspectot mode, these polygons appear hollow (no fill).
What I wanted is to let them appear in the inspector as in the screenshot below:
Is that possible?
Thank you
Best
Jamal
  • March 9, 2014
The Inspector generally sets color to features automatically, but DWG features have certain appearance properties, so they will not be colored by default.
When you need to color them for inspecting, you will have to set explicitly color attributes. Consider using the FeatureColorSetter or overwriting Pen Color and Area Color in the parameters dialog of the Inspector. Temporarily, you can also set colors in the Display Control window of Data Inspector.
I think I've used the second way in my example before.
https://safecommunity.force.com/069a0000003dwSd
jamal
  • March 9, 2014
Thank you very much Takashi for the massive help,
It works fines by setting the vector parameters
gio
Forum|alt.badge.img+15
  • March 10, 2014
U can also click the icao next to the feature name and choose fills, and border colors, or even set them to zero.
I was pretty dissapointed that this styling feature was dismembered, no line width and no symbols for points.
Also the window for displaying vertices...gone!!!
Since patch2.
Is it back in 2014 FME? Hav'nt used that one yet.
Greetings
Gio
jamal
  • March 11, 2014
Thanks GIO
best
Jamal
